05-07-2015, 01:24 PM
Anyone done this or have a clever idea on how to make a bumper quick release. Would like to do it for the 106 so I can quickly pop it off at track days and so on
Quick Release Bumper
05-07-2015, 03:12 PM
Isn't it only held on by 2 bolts on the 106? just weld wingnuts to the bolts.
05-07-2015, 03:20 PM
06-07-2015, 12:43 AM
Separate the main bumper from the solid mounting. Attach the mount as usual the drill a hole either side, then fit bonnet pins to the bumper, use the holes for the securing rods.
So when it comes to it, undo the pins pull the bumper "skin" off, it will leave the main cross member of the bumper attached behind. That's what I'll be doing to the rallye anyway
![]() TEAM CONROD SHITTING RALLYE!
06-07-2015, 02:11 PM
I have ordered some them rubber band ones so use them to hold or on then a cabletie each side under grill for support. Thats the idea anyway. If that fails ill get the spring type ones instead
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead |
| Snapped bonnet release cable | Connor | 9 | 6,369 |
10-12-2012, 11:05 PM Last Post: megwan |
