30-06-2015, 12:09 PM
I've just been on demon tweaks looking at roll cages, which one would people suggest and why?
roll cage
30-06-2015, 07:59 PM
Unless you get a discount I'd shop around then see if they'll match it.
Get a quote from custom cages too. What are you doing with the car?
P1 XSi track car
2.4 LWB T4
30-06-2015, 08:01 PM
i think the normal omp 6 point is £480 inc vat or something. its the cheapest anyway and you can always get the X or harness bars welded in.
01-07-2015, 07:38 AM
I wouldn't go for the basic OMP, it's not a great cage. Id rather spend the extra couple of hundred for a better OMP cage or a Cutomcages or safety devices job. It's a bit of a pain fitting rollcages too, and unless done properly, it'll never be FIA legal.
Here is an OMP basic cage i bought.
Resident cat lover
01-07-2015, 08:07 AM
Custom cages are good but require a lot of time and skill to fit as they are supplied as a box of tubes. They are only as good as the person welding them together.
01-07-2015, 08:54 AM
It's my daily at the moment but will be tracking it soon and it will be my daily until around march time then it's going to be just a track car.
Where are the points the cage mounts to? There's 2 in the boot I know but where do the other 4 actually mount to?
6.2 in boot 2 behind the seats and 2 in front of the dash
Few photo to show you the mounting points of my rallye [attachment=undefined] Astor 6 Fast road/track project
02-07-2015, 06:24 AM
Thanks 7057sam
02-07-2015, 07:21 AM
Custom cages supplied one needs a lot of work to fit right. Ask Phil / Rippthrough
A bolt in cage still is only as good as it's attachment into the car
P1 XSi track car
2.4 LWB T4
02-07-2015, 08:03 AM
I think adams cage has something like 18 points of contact.
02-07-2015, 02:06 PM
Yeah but it was built to massively exceed msa regs (50 x 2mm tube) and its not the lightest thing in the world
P1 XSi track car
2.4 LWB T4
02-07-2015, 02:47 PM
(This post was last modified: 02-07-2015, 02:52 PM by Rippthrough.)
(02-07-2015, 07:21 AM)adam b Wrote: Custom cages supplied one needs a lot of work to fit right. Ask Phil / Rippthrough They redid the cages after Jim had the same issue, apparently they're a lot better now, although there's still issues with the dash bars and rear cross notching. I still won't touch them, if someone wants a cage, they bring the car and have it custom made here to fit the shell - too much hassle fixing other firms f**kups. Mountings for a 6-point are usually either a plate or box foot up front in the side of the footwell, a box foot in the corner behind the seats where the floor rises up for the rear bench/fuel tank, and then either the big crossmember where the beam mounts in the rear or sometimes the rear arches depending on the cage, optionally tied in to b-pillars/a-pillars or stitch welded around the door hole depending on regs. Don't forget to factor fitting costs in if you can't weld/fabricate the feet/mountings into the car.
02-07-2015, 04:55 PM
Pretty sure this was a custom cages job. Albeit a home weld, with the weld mounts ground flat. For that reason it would need work to get it FIA legal.
Resident cat lover
02-07-2015, 07:45 PM
Damn chris we should of both kept are rallye s
02-07-2015, 07:53 PM
Resident cat lover
Looks like a custom cages F2.
Mine doesn't have under dash bars, but does tie into the main bulkhead cross member. Has another cross behind the seats instead of the U shape. Otherwise basically the same. Pretty overkill for what I use it for
P1 XSi track car
2.4 LWB T4
02-07-2015, 09:46 PM
^ true, but the cage will hold the value of the car up if you have cerificates and have done it to the proper standard.
I had a combe saloon racer look at mine, amd inform me the welds were unsuitable for FIA spec, hence i sold the car.
Resident cat lover
Roll Cage in a 5 door | Eeyore | 22 | 4,727 |
12-03-2014, 06:24 PM Last Post: Eeyore |
Show cage? | MIKE-FORD | 17 | 4,145 |
02-05-2013, 10:14 AM Last Post: cwspellowe |
Half cage. | Lukeey | 4 | 1,200 |
29-04-2012, 11:15 PM Last Post: mark_airey |
