Wiring In Fans. I R Stupid
Right, engine fans don't work, the traffic I sit in after work causes the car to get hot in the current weather so I want to put in the slim fan I have.
I've drawn a rather crude diagram of how I think the wiring needs to go. I'm basing this on a diagram Cully gave me before and some stuff I searched on here. It's 12v 80w so I know that means a 6.66 amp draw, a 7.5amp fuse will do.
I'm thinking this cable will be adequate: http://www.maplin.co.uk/p/twin-core-10a-...etre-xs71n
With this fuse holder: http://www.halfords.com/technology/car-a...lder-20amp
Can I use a relay from the car? I have some spares from the old car. 3 greens, 1 grey and 1 orange.
Finally, I have a spare space next to the passenger airbag switch and a spare hazard light switch that I was thinking of using so it kinda looks OEM still lol Haynes is telling me I'd need pins 1+7 on that I believe.
Thanks for any help, I tend to stay away from electrics. (God knows how I managed to work in somewhere that made very technical electrical stuff for 18 months)
[Image: B5XrKbO.png]
Can't you use the air con switch?
(18-06-2015, 08:31 PM)JJ0063 Wrote: Can't you use the air con switch?
Non. Tried that about half hour ago by bridging the connections and nothing happened. They've never worked and I don't know which part of the system is letting it down.
fan drawing here Wink
[attachment=23894]
http://306oc.co.uk/forum/showthread.php?...#pid285010
GTI6 Info
I only vaguely understand that, hence my shite diagram. That is also adding one onto the current system, which doesn't work somewhere.
ignor the second fan and the stat ...then the drawing is what you would be looking at Wink
GTI6 Info
Do I have to wire it into the ignition?
Yes, otherwise you'll leave the switch on and flatten the battery :-)
(18-06-2015, 08:59 PM)tigerstyle Wrote: Yes, otherwise you'll leave the switch on and flatten the battery :-)
Is that the only reason? You would hear them when the engine was off though.
connect pin 30 too 85 on the relay and dont connect 85 to the ing but run the risk of a flat battery
GTI6 Info
One day you won't  Confused
What would be suggested to use for connectors? I'm thinking to use these types from Maplin http://www.maplin.co.uk/p/maplin-interme...blue-n35cy
Is there something better? I'd use those for connecting the relay and switch. I intend to solder the power>fan one.
Wired the fans on both mine.
Just wired straight into the fan plug itself, fed wires through the dash and into a switch placed in the panel where the headlight adjust is. Connect as usual. Use a multimeter to check the switches continuity and then bridge over each wire on the fans to see which they kick in (either single high speed or both at low speed). Wired mine for both at low speed.
It's not the best way to wire them in, but it does work.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
  Fans...HDi fans... HDi slimline fans... wiring.. toseland 3 1,823 07-09-2015, 09:52 AM
Last Post: cully
  Stupid french 405 wiring.. Tmcilvar 0 737 07-12-2014, 11:50 PM
Last Post: Tmcilvar
  Wiring Up Fans to a Timed Switch? bigcheez2k3 8 3,473 22-06-2013, 10:53 AM
Last Post: cully
