Crank pulley help
So don't know how but the keyway has broke on the aux pully end and needs changing but can't get it out so how do I get the crank pulley off if I lock timing and remove belt should it just slide of the shaft thanks in advance
No need to lock timing to remove crank pulley.. Bolt out of middle and lots of wiggling and prying it off
The aux crank pulley has snapped off and gone I need the timing crank pulley off the change the keyway
  Crank pulley Ricky 10 5,476 31-12-2012, 08:20 PM
Last Post: Ricky
