XU10J4R Rev limiter unlock.
Hi,
Does anyone here have an experience about the RFV engine (XU10J4R) rev limiter unlock more than 6500 rpm or remapping ?
Currently, I have the 306 GTI-6 & 406 D8 M/T with some modifications (GTI-6 cams, GTI-6 inlet) , It made the difference response characteristic from both cars. Is there any way to unlock the rev limiter for XU10J4R (Maybe cut at 7,000 rpm) ?
Thank you Itwasntme
[attachment=23257]
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
[Image: 150521115952.jpg]
Buy a GTI6 ecu, get it unlocked and fit that and then you'll have the gti6 fueling and rev limiter
Thank you.
That's mean it's no meaning to have any modification with Bosch MP 5.2 ?
gti6 ecu wont work on this engine, no cam sensor or any brackets for the 4 coilpacks
Stand alone or piggyback may be the answer?
Maybe , The cheapest way to serve my need is swap the engine to RFS.
  Turbocharging XU10J4R... ekjdm14 7 8,854 21-02-2021, 02:20 PM
Last Post: ekjdm14
  XU10J4R gearbox help Zxmad98 3 4,534 29-03-2019, 09:06 AM
Last Post: welshpug
  Oversize XU10J4R Pistons Mighty306 0 2,398 21-10-2017, 10:45 AM
Last Post: Mighty306
