10-05-2015, 09:29 PM
Most of the time when I come off the throttle to change gear I get a blow off valve noise (i dont have one fitted) any ideas what it could be?
Whistle sounding like blow off valve
10-05-2015, 10:06 PM
dying turbo possibly.
intake pipe to turbo has come off. Wishes for more power...
10-05-2015, 10:17 PM
Had this turbo on for only 6000 miles, was in good condition and only done 63k
2nd one is a possibility ![]() Cheers Piggy ![]()
11-05-2015, 01:54 AM
I also have this problem but think my turbo is dieing lol it's done 190k! Still boosts fine tho
11-05-2015, 06:18 AM
Easiest way to check the intake pipe is to have a look, run your fingers around it to check there's no gap. Can go in through the driver's wheel arch.
11-05-2015, 09:10 AM
play in turbo centre bush??
haynes manual suggests some may have an oil feed line filter?? shaft floats on oil pressure and bush?
12-05-2015, 08:09 PM
Play in bush giggidy
12-05-2015, 08:12 PM
Where can I get one of these bushes from? May be turbo upgrading in the next 6 monthsor so so is it a thing needed to be done asap or not?
Cheers
13-05-2015, 04:57 AM
The central shaft sits on bearings, you can get new bearing and seal kits from turbo specialists. It's a pretty involved job, not worth it for six months use imo.
13-05-2015, 07:49 AM
Cheers Poodle
Yeah will just sit it out then Free dump valvve noise I suppose ![]() |
best sounding airfilter | mattydturb | 11 | 1,239 |
20-02-2015, 08:27 PM Last Post: mattydturb |
Loud turbo whistle | Brucky | 10 | 2,459 |
14-03-2014, 06:48 PM Last Post: Brucky |
loud turbo whistle | Jukie88 | 32 | 4,504 |
22-02-2014, 06:12 PM Last Post: pro_steve |
