Threads: 1
0
Car Model/Spec: Toro 455-D
This is my first post and I'm hoping for some help from across the pond since there is not a lot of expertise on these here in the states. So I have the XUD9AI in a lawn mower (toro 455-D groundsmaster) and the fuel gauge doesn't work very well. I ran out of fuel the other day. I changed the fuel filter and primed the system and got it running. But now it will not rev up much above idle and has limited power. It runs smoothly (almost too much so) until it is under load and then it starts to choke down and struggle as if it is starving for fuel. It has a Lucas pump.
I've checked for air leaks. The fuel filter was very dirty when I changed it. Anyone ideas on where to start... pump, injectors? It was running fine before so I'm thinking it should be something simple.
Thanks.
JC
Threads: 11
5
has the fuel tank pick up inside the tank got a filter on? as this maybe slighly blocked (im not sure on a lawn mower).
Threads: 41
12
Car Model/Spec: Dtractor
Im wondering if the fuel filter relies on vacuum to pull the fuel through and up from the tank. In which case this could simply be letting in air. Try a pipe off the injection pump straight into a bottle (CLEAN!). See how she runs there i'm sure you'll find it more responsive.
Threads: 541
124
How big is your lawn to need one of those?
Threads: 1
0
I did remove and check the pickup tube that is coming from the tank. I haven't tried to run a direct line from a clean fuel source into the pump and bypass all the filter/primer etc.
We use it to mow an olive orchard. At 10.5 ft wide, it barely fits down some of the rows.
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
10-05-2015, 01:23 PM
(This post was last modified: 10-05-2015, 01:25 PM by toseland.)
new fuel filter offering too much restriction possibly.. there are no kinked fuel lines and or blockages are there?
injector issue would rarely affect all 4, most often it would run like hell cause 1 had packed up..
that is crying out for an FMIC and turning up the fuel a little though, the LOLS would be epic from that if tuned haha
/Toseland
Threads: 163
53
Car Model/Spec: 406 HDI
First thing I'd check would be the fuel filter housing, make sure you sealed it back up. Need some pics of this beastie!
Threads: 163
53
Didn't even know they put XUDs in stuff like that, strangest thing I've heard of with one is the FSO Polonez [emoji38]
Threads: 42
28
sweeeeet.
I worked at a bike shop / lawn mower shop years ago and Toro was one of the brands, good mowers, didn't know they went this big!
the councils all over the uk have ones this big and road legal, wonder whats in them?? probably kubota with a cvt.
Threads: 163
53
My mate drives one, 600cc Rotrax diesel.
