My fuel light is useless on the 205 and I think I almost ran it down to the bottom of the tank. Since then I've lost top end power and sometimes if I'm lucky it will have full power briefly (the boost shoots up and it pulls well for a second). Ill be doing the oil, filter and fuel filter but just wanted to check what it could be!
Loss of power, likely due to clogged fuel filter?
15-04-2013, 08:04 AM
Maybe fuel filter and try and blast the fuels with an airline, that should help !
Disclaimer - I think it would be ok to blow back thought the fuel lines with an airline but check with someone else first
![]() the smokey old bus that sounds like a tractor...
15-04-2013, 08:46 AM
Yeah fuel filter more than likely!
15-04-2013, 06:41 PM
It was indeed fuel filter as I thought.
Ill get a picture up when I'm on a PC later. It's hands down the worst fuel filter I've ever seen!
16-04-2013, 10:07 AM
what in fcuks name have you been putting in your tank?!!! do you run waste veg oil? . . :o
16-04-2013, 10:18 AM
Haha.
![]() I've literally ran it purely on diesel as its still on a lucas atm! Sickening isn't it! Going to do the oil and filter this week too as if the fuel filters in that state then...
16-04-2013, 10:23 AM
(16-04-2013, 10:18 AM)silverzx Wrote: Haha. summit wrong there mate . . . god knows what but that is seriously wrong .
16-04-2013, 10:41 AM
The tank could probably benefit from a good clean, is there anywhere else I should check how blockages?
16-04-2013, 01:06 PM
(16-04-2013, 10:41 AM)silverzx Wrote: The tank could probably benefit from a good clean, is there anywhere else I should check how blockages? by the look of that filter i'd clean the tank out and change filter again in a few weeks . .
16-04-2013, 01:46 PM
Zzz, how would I go about cleaning the tank? Does it drop down from underneath or?
16-04-2013, 01:52 PM
(16-04-2013, 01:46 PM)silverzx Wrote: Zzz, how would I go about cleaning the tank? Does it drop down from underneath or? lot of faffing about mate, is this a 205 or 306 btw? . . . .306 tank is accessed under rear seat, maybe just syphon fuel out and clean out the sludge . .
Swarf In Fuel Filter Housing | jordanhdi | 11 | 6,012 |
26-09-2016, 11:55 AM Last Post: pug306driver |
| Removing the fuel filter housing, but what is this behind it? | Iaitoo | 2 | 3,086 |
27-04-2016, 05:33 PM Last Post: Iaitoo |
| Drove 150+ miles with clogged fuel filter - now won't start | mikes | 21 | 10,872 |
13-04-2016, 07:17 AM Last Post: mikes |
![[Image: signature.png]](http://s22.postimg.org/cgh3ss11t/signature.png)
![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg)
![[Image: IMG_0404_zpsef2b0717.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%202%20Pug%20205%20DTurbo/IMG_0404_zpsef2b0717.jpg)
![[Image: IMG_0403_zpse17d7206.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%202%20Pug%20205%20DTurbo/IMG_0403_zpse17d7206.jpg)
![[Image: IMG_0400_zpsc2a48a16.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%202%20Pug%20205%20DTurbo/IMG_0400_zpsc2a48a16.jpg)
