24-04-2015, 11:05 PM
Calliper is free and had a refurb kit put on today, wheel bearing also very free, whwn the calliper goes on then it binds, any ideas?
Strange Binding Front Wheel
24-04-2015, 11:18 PM
The disc looks fine, so not sure, anything else it could be?
Will upload a photo tomorrow
25-04-2015, 01:09 AM
have you DTI'd the disc, doesnt take much of a warp to cause it to bind! can be as little as 0.25mm
25-04-2015, 08:03 AM
I haven't no but its a consistent bind all the way round when turning the wheel so don't think its that, although will take a better look today, other side free as anything
Cheers
25-04-2015, 08:18 AM
Discs the same offset?
Sliders free? Hubs look the same?
25-04-2015, 08:35 AM
25-04-2015, 08:40 AM
Have you also checked the brake hose? Can sometimes collapse. Remove the pads. Pump the piston out a bit. And try and push it back. If its seized or hose I collapsed it wont go. Undo the bleed nipple and try again. If it goes back the hose has collapsed. If it doesn't calliper is dead.
Tried that Bashbarnard and piston went in fine.
Strange thing is when the calliper was moved further outwards towards me the brakes stopped binding on, but in its normal position it was binding
25-04-2015, 08:52 AM
Bled the brakes recently?
sounds like your caliper. i know you have just rebuilt it but was everything pristine when you done so.
25-04-2015, 08:55 AM
That brake was bled yesterday yeah, yescalliper was all good
25-04-2015, 10:28 AM
Bits of crap stuck between the carrier and mounting face on the hub perhaps? Running out of possibilities tbh, assuming you haven't changed anything else that hasn't been mentioned. At the end of the day, if you didn't have the problem before you did the work then it's got to be an issue with something that you've changed or work done.
25-04-2015, 10:34 AM
Ive had this problem before I had the calliper refurbed
All smoothed off yesterday Poodle and no difference :/
25-04-2015, 04:40 PM
(This post was last modified: 25-04-2015, 04:42 PM by daddyfixit.)
I assume you had the flexy clamped off while the caliper was off ???
chance is you have caused it to break up inside and the stainless reinforcement has kinked and is holding the internal rubber pipe closed after you have released brake pedal ? to check it ; press brakes, check it is binding and quickly open bleed nipple---if it rotates now then the flexy is at fault.
25-04-2015, 05:38 PM
Yes flexi was clamped
Ordered a new flexi so will see if it cures the problem!
26-04-2015, 07:01 AM
Oh ok, that's a pain... Might as well test the part first, could be there all month ordering parts you don't need otherwise. I assume it's just the one wheel you've got this issue with? Is the wheel bearing definitely ok?
26-04-2015, 07:12 AM
Just the drivers wheel poodle yeah
Yeah wheel bearing all good and free spinning without the calliper on Calliper related so a few people good with cars ive asked said brake flexi hose (uncle and a few mechanics)
26-04-2015, 07:15 AM
Oh yeah, it's certainly a possibility, fingers crossed that fixes it then.
26-04-2015, 08:04 AM
Cheers Poodle
Hope so too as its bloody annoying! :/
| Front wheel bearings | Mighty306 | 0 | 3,400 |
22-08-2020, 02:03 PM Last Post: Mighty306 |
| Knock from the front left wheel area | johnny625 | 15 | 17,741 |
08-05-2019, 03:15 PM Last Post: Zxmad98 |
| rear brake binding | hedgeling106 | 12 | 7,988 |
10-12-2016, 11:20 PM Last Post: Piggy |
