Bosch pump manual stop lever?
Well just after boschin my dturbo and realised the o ring on the throttle shaft needs replacing.
My question is this, is the manual stop lever actualy needed or does it serve another purpose?
Because if all it does is stop the engine then ill cut the bit on the inside of the pump to make refitting the top half easier. Thanks.
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
You can take it off but better to learn the knack, you have to angle the top of the pump towards yourself and slip that side on first, it's quite easy once you get it, I know it seems really awkward at first but it's not when you know how Smile
Also wind the max fuel out and hold the stop lever as you do it Smile
I think I read somewhere that the manual stop lever also acts like a buffer on start up ie to help stop that little puff of smoke you get when you start the car.
Most people just get rid of it to be honest, myself included.
  Slack in bosch pump? dt_ 14 12,371 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,630 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,206 12-03-2019, 06:47 PM
Last Post: Forby
