New rear beam
New rear beam
Hi guys,
Well after driving my car for 4 weeks now I've come to the conclusion she needs a new rear beam.
One side of the car is slightly higher than the other, and it doesn't feel very stable cornering, even at 30 going round a roundabout.
Where could I get a reconditioned rear beam? And what would the cost be?
All comments welcome as always. Smile
Stef205 on here does a healthy trade in rebuilt rear beams.
Might be worth checking it's not a dead shock causing one side to sit lower than the other
Thanks for the replies guys!
I'll ask my mechanic to check the shocks when she goes in for her driveshaft seal and brakes.
What price is it roughly for a new Phase 2 rear beam? And can you buy one that lowers the suspension a little?
stef's your best bet, be careful of compainies selling refurbs on ebay as ive heard and seen what they call a refurbed beam
Link to his add
http://306oc.co.uk/forum/showthread.php?tid=28869
I can sort you with a recon beam if needed. I can set it to your required height and use oem quality parts. As been kindly posted previously check out my thread for my budget builds should you not want to spend a lot.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
(20-04-2015, 07:22 PM)Stef205 Wrote: I can sort you with a recon beam if needed. I can set it to your required height and use oem quality parts. As been kindly posted previously check out my thread for my budget builds should you not want to spend a lot.
Thanks Stef, if the shock isn't away I'll be purchasing a new rear beam from you! Smile
Would you need my beam in return?
yes they are on an exhcange basis Smile
05' Evo 9 IX GT
Team eaton.
  Rear beam ...the good and the bad Mighty306 35 29,632 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,242 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 14,654 18-03-2019, 03:40 PM
Last Post: MOK
