Threads: 29
0
Car Model/Spec: 306 2.0 8v Turbo
Given 2 thank(s) in 2 post(s)
16-04-2015, 03:32 PM
Heres a good one.
Looking at my friends XSI today, when you rock the car from side to side it makes a metallic 'TINK TINK', Noise. Its had new shocks done recently, but we cant find exactly where this noise is coming from.
When you drive the car the noise gets louder and sound horrific from outside.
Any Clues?
1999 2.0 8v Turbo 306
You Tube: 832 Performance
Threads: 136
11
Car Model/Spec: 306 hdi stage 2 & 205 DTI
Given 39 thank(s) in 39 post(s)
Some thing loose on the rear beam?
Check the rear ARB plates are tight
Threads: 29
0
I will have a look tomorrow
Threads: 58
5
Car Model/Spec: 205 gti6 supercharged
Given 16 thank(s) in 16 post(s)
as paul said arb flags renowned for doing it, remove it clean the thread with a tap and refit with thread lock
Threads: 29
0
Found it, Seized anti roll bar on the RHR, Removed the anti roll bar, cleaned it up greased and re-fitted, job done.
