06-04-2015, 12:43 PM
Does anyone kno how to lossen the powere steering belt so I can slide it onto the pully properly ??
power steering belt not on the pulley properly
06-04-2015, 01:16 PM
Air con or non air con? If it's aircon, there's a auto adjuster in the driver front wheel arch. There's a space in the adjuster to fit a 3/8 ratchet then you just push it loose. If it's non air con, there's a 6mm Allen key bolt down the side of the PAS pulley. Loosen that then the idler that it sits against, there's 2x 13mm bolts holding that against the PAS bracket. Loosen them and the belt will loosen off.
1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft |
Bottom aux belt pulley removal | callumcull | 16 | 3,848 |
21-10-2013, 07:57 PM Last Post: Piggy |
Gti power steering | Niall | 3 | 1,510 |
20-07-2012, 10:21 PM Last Post: Matt |
