Drill bit/tap size for 3/8" bspt boost gauge tapping
It's been a very long time since I dealt with these kind of things (back in college 8years ago)
I've ordered a brass bspt adapter 3/8 tapping with 1/4" hose connection.
Now logic tells me to use a 9.5mm drill bit? Which is what size 3/8" is roughly. Do I just use the barb as a tap or do I need to use a proper tap?
I would use a 6.5-7mm drill bit and a proper tap to make the thread (making sure the pitch is the same)
Google suggests somewhere around the 15mm mark?!?!?!?
https://www.google.co.uk/webhp?sourceid=...drill+size
Personally I'd buy an M8 or M10 bleed nipple and drill for a standard metric thread (M8 can be done with a 6.5mm bit that most people have)
I used a 1/8 bsp taper tap with a 1/8 bsp taper nipple and used a 8.6mm drill. If thats any help.
(06-04-2015, 12:45 PM)Dum-Dum Wrote: Google suggests somewhere around the 15mm mark?!?!?!?
I saw that as well and I really didn't think it was right, hence asking on here
I think I'll change my approach to this
Aren't bsp sizes stated at X-1/8th, X being the actual size? So 3/8bsp is actually 1/2"? I may be thinking of npt...
Be careful with BSPF, BSPP and BSPT. BSP is a pipe thread form and therefore the size can be misleading. It used to denote the pipe bore, but it doesn't really work nowadays. Taper tapping size is smaller than BSPF or BSPP tapping size.
3/8 BSPT tapping would be a bore of 9.525mm, but tapping drill for that size is 37/64 aka 14.75mm.
http://www.tradezone.co.nz/tapanddie/dri...pt-tap.htm
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Should of realised it was inside bore.
Think I'll re order a m8 nipple
Where's your Zeus book?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
http://m.ebay.co.uk/itm/Barbed-Threaded-...1600317066
I've opted for this.
Lost you there Alan lol
(09-04-2015, 08:49 PM)Paul_13 Wrote: http://m.ebay.co.uk/itm/Barbed-Threaded-...1600317066
One of these....Will tell you drill sizes for tapping, amongst other stuff.
[Image: zeus-book-500x500.jpg]
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
You can get it here, but iirc it's not got bspt in. Mine is at work.
http://www.green-oval.com/data/zeus.pdf
Nice, I'll get myself a copy of that
What I've ordered now. Bit of ptfe/loctite will be all good
  Drill bits Dum-Dum 20 9,784 30-03-2017, 11:12 AM
Last Post: Dave
  what drill to buy!!! bashbarnard 31 17,299 28-12-2016, 07:31 PM
Last Post: Rippthrough
  best drill bits procta 33 18,372 21-03-2015, 08:33 PM
Last Post: Paul Baldwin
