Peugeot 306 1.9 Diesel Driveshaft fit 306 Hdi Model
Hey new to the site
I have a 00 306 hdi estate, Just wondering would the driveshaft from a 99 306 1.9 straight diesel fit the hdi, its a four door hatchback, Would just a part from the hdi model fit and do I need a part from a estate or will any part from 97+ fit? Thanks
Yeah it will fit
[Image: av5ym8.jpg]
So any model from 97+ or does it have to be a diesel? thanks
Yeah, diesel will definitely fit.
I think the 1.8 and 2.0 petrol ones will too but don't quote me on it. Id stick to diesel tbh
Just be wary of ABS and Non ABS
[Image: av5ym8.jpg]
ok , the 99 has no abs so it wont fit??
Some have hollow shafts that will fit, others have solid thinner ones that wont. Got caught by it myself on one, hub was different
(02-03-2015, 07:53 PM)HDi--Power Wrote: Some have hollow shafts that will fit, others have solid thinner ones that wont. Got caught by it myself on one, hub was different
anyway of knowing without seeing the part?
thin shafts will fit fine, the cv splines either end are the same, as long as it has an abs ring you'll be all good, its only the 1.4 and 1.6 stuff that wont fit.
ok thank you for your help
  HDi 266mm Calipers Fit Base Model Hubs? Alan_M 4 2,898 11-06-2015, 09:21 AM
Last Post: qbimmer
