HDi 266mm Calipers Fit Base Model Hubs?
Can someone tell me if HDi 266mm Calipers and discs will fit on base model hubs (It's a Ph2 non ABS model)?
The brakes are just about dead on the 1.4 306 and are basically shit. I'd like to fit my spare set of HDi calipers if possible.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Yes they will.
As said above, straight fit mate as are the 283's if you ever fancy those Smile
with regards to drive flange offset and caliper mounting lugs they are all identical yes.
its worth running a tap through the caliper mounting threads beforehand as the open end can rust up, stopping the bolts from clamping down on the carrier bracket sufficiently even though they may torque up fine.
course they will
volkswagen service
  266mm HDi Calipers on 1.4 Alan_M 5 3,294 04-05-2017, 05:59 PM
Last Post: Frosty
  406 HUBS thethorne 45 23,874 30-11-2016, 09:13 AM
Last Post: Janne L
  Best 266mm Calipers/Brakes MY95 11 4,975 19-09-2015, 08:40 AM
Last Post: MY95
