Half leather phz2 in a phz3 air bags? resistor?
im swapping phz three interior for phz2 half leather in way better condition than my ripped and torn interior, the only problem is my interior has side airbags and this one doesnt so what can i do to get around the air bag light that i will inevitably get like my abs light that wont turn off lol.
1.5 to 2 Ohm resistor in sieres with a 2amp fuse
Cully little bit more info, how do you do this?
hope this helps
Ahhh so this is using the wiring under the seat? I think my air bag light must be on constantly as the bulb was removed by previous owner. I have s16 seats in mine guess the previous seats had side airbags. Will this need doing both sides?
yes needs doing at each airbag you disconnect
Sweet which ones are the air bag ones again? Will get this done, instead of cutting wires could you use the male spade connectors? Not keen on cutting the wiring
Don't mean to hijack your thread Matt, but would this also work in reverse, I.e. ph3 seats with side airbags in a ph2 without? My airbag light has been flashing at me since I put the seats in.
No worries wingnuts im sat watchin paint dry. will upload photos soon
WiNgNuTz Wrote:Don't mean to hijack your thread Matt, but would this also work in reverse, I.e. ph3 seats with side airbags in a ph2 without? My airbag light has been flashing at me since I put the seats in.
Flashing airbag light is pretensioners. There not connected properly.
I don't even have a airbag light Wink
Matt Wrote:I don't even have a airbag light Wink
Mot fail!
Theres your answer then Matt! Get the stuff and ive got solder and heatshrink we can use! Smile
Mot fail!
I know that's why I need to sort mine Smile
Mot fail!
how are they gunna know if theres a bulb in there or not? (or are they supposed to come on ignition stage?)
yes the lamp comes on as part of system check when the ign is switched on
Lamp comes on for 3-4 seconds, as does the abs ninja
My ans stays on all the time. have u got any fluxx sam? I have solder and soldering iron.wat fuse and resistors should i use?
Abs sensor is gone I would presume and cully mentioned up there what bits to use Wink
Its my mobile jidkng bits from me soz grr
Mot fail!
That's why I need your pretensioners srowell, ones gone off and airbag light flashing.
4way, they test ignition lights, Tim checked mine at MOT and said it would fail next year as the system tests its self and light goes out if the system is ok, hence I need pretensioners as ones gone off
[Image: siggy1.jpg]
MattDM306 Wrote:My ans stays on all the time. have u got any fluxx sam? I have solder and soldering iron.wat fuse and resistors should i use?
Dont need flux Smile
  In need of advice or help to restore 306 Half leather seat... MattDanPug 5 3,471 19-09-2016, 07:48 PM
Last Post: MattDanPug
  Trying to find the leather/Half-leather seats. distinctionx 7 4,145 25-11-2015, 07:04 PM
Last Post: 7057sam
