10-02-2015, 01:33 PM
Just pulled the plug out by the screen wash bottle and bridged pins 1-3 to do the ac button for fans mod. I saw on the guide that is said to unplug the actual ac compressor aswell, is this necessary?
Ac button mod for fan
10-02-2015, 01:46 PM
Yes.
Obviously! Otherwise you are turning your AC pump on! Wishes for more power...
10-02-2015, 01:54 PM
Whats this thing? Does anyone have a link to this mod? Cheers
View my build thread here
http://306oc.co.uk/forum/showthread.php?tid=28072
10-02-2015, 09:23 PM
Cant find it anywhere :/
10-02-2015, 09:32 PM
(10-02-2015, 01:46 PM)Piggy Wrote: Otherwise you are turning your AC pump on! As if anyones AC system has enough gas left to turn on... JTaylor - Not sure about a guide, but you unplug the brown plug on the AC pipe infront of the PAS pump and link two of the pins. This turns the AC button on the dash into a fan switch to manually control the fans.
10-02-2015, 10:07 PM
Haha yeah sounds good and tbf makes sense as apparently these cars have rubbish AC haha
11-02-2015, 10:44 AM
Its pins 1 - 3 for high speed and 1 - 2 for low speed
11-02-2015, 03:01 PM
(10-02-2015, 09:32 PM)Toms306 Wrote:(10-02-2015, 01:46 PM)Piggy Wrote: Otherwise you are turning your AC pump on! This mod tricks the system into thinking its full, so will turn on with no lubrication(assuming ac system is empty) |
