Offside driveshaft
Offside driveshaft has gone, its it an easy/cheap job or is it a garage job?
Easy enough, intermediate bearing will be seized and need a big hammer though.
Yeah any guides to removal on here? Search is useless on this app Sad
Jack up
Remove wheel
Remove lower hub pinch bolt and nut (16&17mm)
Pop hub off balljoint
Remove hub nut (35mm, very tight)
Pull hub towards you and shaft pops out
For drivers side need to remove intermediate bearing (2 L shaped bolts with 11mm nuts need undoing) and hammer bearing out
Make sure you either drain the gearbox or catch the fluid that comes out and then replace it afterwards.
(01-02-2015, 06:14 PM)Toms306 Wrote: Jack up
Remove wheel
Cheers, will give it ago, managed to find both shafts for £20 off a lad 10 mins away breaking his 5 door, I presume they will be the same?
I think 1.4/1.6 shafts are smaller, but bigger engines are all interchangeable. Also if you have ABS, you will need ABS shafts.
Don't think it has abs, haven't slammed on enough to notice though
And his is a 5door xud Smile
The driveshafts aren't distinguished by doors... lol
Check for an ABS pump in front of the little fusebox. If not then yeah they'll fit fine. Smile
Will do, cheers lads
  Handbrake Offside LewisG 3 2,757 05-04-2014, 12:25 PM
Last Post: LewisG
