Yellow connector in engine bay
What is connected to the other end of the yellow connector?
It's by the thermostat housing.
Peugeot Dealer kindly left mine loose and dangling down by the gearlinakges...
Engine seems to run fine without it though! Thinking either an oil/water sensor?
[Image: nrZDSMu.jpg]
Oil level sensor. I guess your oil level gauge doesn't work now...
YES!
When it should be registering at startup it does a few full sweeps, I thought that was because I hadn't reset the service counter for a while and it had gone into panic mode!
Lol, should be fine when you plug it back in, its not connected to the service reset at all.
funny.. i know someone else who leaves these unplugged =D
/Toseland
I didn't did I? Confused
Lol if I did though. Blush
  Can this connector be cut off? (egr?) tigerstyle 2 2,250 20-12-2015, 05:28 PM
Last Post: tigerstyle
  Wire with blue connector under seat? aaron_one 9 4,562 28-10-2015, 10:27 PM
Last Post: Toms306
  Connector. MartinL 2 2,681 02-06-2013, 09:23 PM
Last Post: MartinL
