egr blank & mbc please help chaps
how is the best way to blank my egr correctly, could anyone run me through it (is the dw10 blanking plate on ebay good to use? and how do i fit a mbc? ive got a brass ball and spring one.
cheers chaps
so on the inlet manifold the egr pipe comes off there and you ned to fit a blank between the two. See if you can find the push in type. Its easier to fit instead of trying to get it to line up and put the bolts through....
http://www.ebay.co.uk/itm/121364431799?_...EBIDX%3AIT
will it seal well? do you have any tips on fitting the mbc?
Manual boost controllers are relatively easy to fit, it seems a hard task at first but its not. I removed the track rod end from the hub to give myself some arm room then its a case of get your arms in there and remove and fit pipes
  egr blank fgrc76 12 6,400 24-04-2015, 10:54 PM
Last Post: Iceman299
  manual boost controller and egr blank plate fitting, please help dirtyboost89 6 4,301 02-03-2015, 11:50 AM
Last Post: dirtyboost89
  EGR Push in type blank? pugdan95 5 3,852 09-01-2015, 07:21 PM
Last Post: doski
