Glow plug light not coming on
Car is a 1998 D turbo S
Just put a new glow plug relay in and checked fuses
No glow plug light coming on dash
No power going to glow plugs
Have you got the leads on the right way on the relay?
One is from the battery the other goes to the plugs
(17-12-2014, 04:52 AM)Paul_13 Wrote: Have you got the leads on the right way on the relay?
The O-ring connections will only go on one certain pole as the O rings are different sizes, Black is my current bosch relay, green one is the new nagares relay
Brown wire and a White wire both tight and have removed any corrosion
Symptoms; no light on dash, no click from relay, no power to glow plugs so no heat
[img][Image: IMG_1060_zps8e6d375d.jpg][/img]
[img][Image: IMG_1056_zps6b4ff0dc.jpg][/img]
The bigger terminal of the 2 should have the feed from the battery
Sad Airbag light on, other lights not coming on TULL3RZ 0 2,634 25-12-2017, 08:13 PM
Last Post: TULL3RZ
  glow plug relay happypug 0 2,015 05-01-2014, 01:01 PM
Last Post: happypug
  glow plug relay Poodle 4 3,749 10-08-2013, 05:03 PM
