XUD9TE high flow oil pump on XUD7TE
Hi everyone,
I'm Paulius from Lithuania and this is my first topic here. I have a Citroen BX 1.8TD (XUD7TE) and am currently messing with it's motor.
XUD9TE has supposedly regular pressure (6bar), but higher flow oil pump. I am thinking about fitting it to XUD7TE to increase low RPM oil pressure and have nominal pressure at lower RPM.
The XUD9TE pump goes along with 18 teeth sprocket on crankshaft and 48 segments chain while XUD7TE (and other XUD7 and XUD9 motors) uses 26 teeth and 52 segments. I do not yet have XUD9TE pump, but it might fit with the larger sprocket on crankshaft and longer chain.
Any experience with such mod?
Are there any cons of having higher flow pump turning 1.4 times faster than intended?
Thank you for your input!
I cant see the benefits to be honest
You wont cause too much pressure due to pressure release valve
I'm not sure the XUD9 has the higher pressure spring, the GTi6 does though.
The spring makes no difference apart from on initial cold start - the oil pressure isn't up against the regulator any other time - too thin!
Thank you for your thoughts.
My XUD7TE already has 6 bar spring (or should have according to part catalog) thus the question is whether having a higher flow pump is a good or bad thing. If it is a good thing, would larger crankshaft sprocket provide any additional benefit?
Thanks for replies.
I eventually fitted a XUD9TE oil pump. It is a straightforward replacement - only sumps needs to be removed. Pump has much larger internals, but externally is fully compatible. The pressure spring is identical to XUD7TE pump's spring so I suppose it is 6 bar spring.
I'll come back to report oil pressure figures when the motor starts. Hopefully starts Smile
  Flow vs psi? Lwilliams 19 14,398 02-08-2020, 12:22 PM
Last Post: ekjdm14
  pump oil xud9te or xud11bte niciou 0 1,984 20-06-2017, 10:14 PM
Last Post: niciou
  recommended BOSCH fuel pump for XUD7TE assembled 24 17,907 24-03-2016, 03:23 PM
Last Post: assembled
