11mm Bosch
Hi there as above I'm after an 11mm pump in gd working order thanks
give me a month or so and I may have mine for sale.
ninja
(10-12-2014, 05:07 PM)Piggy Wrote: give me a month or so and I may have mine for sale.
ninja
Would that be with lines and injectors piggy?
How much
Nah just pump.
Piggy u still getting rid of that pump or u not sorted yet
Erm not yet. I am in middle of rebuilding and resealing a 9mm...I could source a 11mm head if you really cant find one anywhere else
Aren't 11mm pumps put on older transits sure I read that somewhere?
Among other motors yeah
But basically only the head is used from the transit pump
I'll keep looking around but I'll let u know thanks
if that is the case i have several 11mm pumps sat on engines if you still need one
How much for a tranny pump ?
(07-01-2015, 11:05 PM)mspdan Wrote: if that is the case i have several 11mm pumps sat on engines if you still need one
Location and how much for one and r they straight bolt on to the Xud thanks
no defo not bolt onto the xud, they need stripping and parts from both joining together.
Ok that's fine how much would u want for one
how much of a rush are you for one i have 5 stock 9mm pumps at my workshop i can /could build to a 11mm / put all new seals in. its just getting the time to do it.
  Wanted: 11mm bosch Chris_90 8 5,185 18-08-2015, 03:53 PM
Last Post: Chris_90
  Wanted: bosch pump and transit 11mm pump spike2002 8 4,648 14-10-2014, 06:41 PM
Last Post: spike2002
  Wanted: 11mm bosch pump setup maffy 2 2,496 05-02-2014, 09:37 AM
Last Post: Piggy
