Driver's seat too high.
Any way I can get my front seat to go lower, It's adjusted all the way down but still quite high, my brother's pov. spec ph.1 is lower and that's a fixed height seat :?
Cheers Smile
You sure its adjusted the right way lol? I found they were pretty low in 306s tbh!
yep, 100% sure!
Jonny81191 Wrote:yep, 100% sure!
Well without changing brackets I don't think there's an easy way to lower them tbh....have you tried moving the seat back and changing the back angle instead...?
yeah but *if* (when) I'm chucking it round country roads, I'd rather stay in my seat and not worry about being a bit higher up.
IIRC 5dr seats are higher than 3dr if that makes a difference.
Putting 3dr seats in a 5dr leaves them higher by maybe an inch. Its really annoying but I don't think its that hard to change, one of those things on my to do list!
My poverty spec seats in my XLdt were a tiny bit lower than the ph3 half leathers I have in it now. Mine is also adjusted all the way down. I just got used to it though.
[Image: MIRKxNP.jpg]
  driver's seat bolt's Andrew75 12 6,614 29-04-2016, 05:34 PM
Last Post: Matt
  Patching my driver's seat chylledapps 12 6,368 10-12-2014, 10:48 AM
Last Post: Toms306
  Driver seat issue Nathan1305 2 2,646 09-03-2014, 03:39 PM
Last Post: Nathan1305
