URGENT: Ticking on Ignition
Hi Guys,
Something has happened to the car in the past few days. I went back to it after sailing and it would only tick when i tried to start it. Had to bump start in the end!
A few hours later after an hours drive it would turn over very slowly but not fast enough to fire. With everything turned off it eventually started.
Yesterday it again started very slowly twice. When driving the voltage gauge says between 13 and 13.6v. What do we think?
Failing alternator or battery?
Sam
Battery. But double check the alternator chargeing as well with multimeter. Cold will kill off a lot this time of year
Ahhh thats very frustrating its a Bosch Silverline which can only be a year old!
It's probably the alternator tbh, my my Bosch still works fine after 2.5 years starting diesels!
Also check the connections are tight on the alternator and battery. Unless the omex is draining power with the ign off anyway!
It's the battery. I'd put a pint on it and don't pay any attention to the voltage gauge on the PLX.
This weather kills them.
Not after a year though! Especially on a light petrol engine without glowplugs...
If it is the battery at least its under warranty.
Can I take it back to ECP with no proof of purchase and get a swap? All I have is a screenshot of the it and the 'eurocarparts' seller name in my purchase history on ebay!
(24-11-2014, 09:48 AM)SRowell Wrote: Ahhh thats very frustrating its a Bosch Silverline which can only be a year old!
Avoid silver calcium batteries, they're absolute naff and fail almost instantly when they go as it sounds like yours has. Stick with a regular lead acid!
Got it on the charger just to make sure its got a decent charge before I leave for London tonight! Got jump leads with me too!
Started up a little bit slow this morning but did start fairly easily!
  HDI ticking noise from passenger airbag Potta_91 5 3,787 28-05-2014, 05:48 PM
Last Post: Mattinthehat
  Air recirculation Valve Ticking HELP!!!! mattgreene 6 4,145 28-10-2013, 06:38 PM
Last Post: mattgreene
  Indicator ticking when I'm not even indicating? Help CalNeedham3061.4 9 5,280 13-08-2013, 09:49 PM
Last Post: Toms306
