19-11-2014, 04:23 PM
Hoping someone can help. Apologies for the noob question but I'd sooner make sure I get it right:
My car (phase 1 XUDTD) has been leaking coolant for a while and it appears to be from around the thermostat housing. The existing seal on the thermostat has a slight nick in it and I temporarily bodged it with gasket seal but there's still a little bit getting out.
I figure I may as well replace the whole thermostat at the same time with a cheap and cheerful one.
ECP seem to have two which are ever so slightly different. Which is the one I should get?
I assume it's just a case of undoing thermostat housing and taking the old thermostat out, putting the new seal on the new thermostat and bolt it all back up again (+ refill/bleed lost coolant)?
I'm reluctant to undo the thermostat housing to measure the current one as I'd rather not disturb the existing seal and what's left of it.
Cheers.
- http://www.eurocarparts.com/ecp/c/Peugeo...f81&000325
- http://www.eurocarparts.com/ecp/c/Peugeo...8b2&000325
Cheers.
