imbalance on rear brakes
Hi, the car failed its mot on an imbalanced on the rear brakes any idea what i should be looking for to resolve the issue?
cheers
Gaz
ps. its a 1.4 meridian with drum breaks and girling shoes
Service brake or handbrake?
Just adjusting them properly should do the job though.
How bad the imbalance?
Take the drums off as I expect there will be a fair bit of dust in there. Give it all a clean and adjust and then put it back together. And while the drums are off check the wheel cylinders aren't seized
mine was the same last Saturday, it failed;
drums off, de-dust, clean and adjust the auto adjuster up as drum came off too easily------put it on to check if drum spun, decided to loosen the adjuster..............as I pulled drum off the wheel bearing sh*t itself into about 10 pieces !! ordered new bearing & pressed it in, all happy and mot,d now.
  Brake imbalance, ABS light on. CaptainHair 7 12,373 24-01-2024, 11:08 AM
Last Post: Mighty306
  Nasty vibration coming from the rear brakes johnny625 9 8,477 12-04-2020, 10:26 AM
Last Post: johnny625
  What Rear Brakes Do I Have cateraxe 7 4,893 07-11-2016, 10:19 PM
Last Post: miles
