11-11-2014, 01:52 PM
I cant get the clip on to a cv boot can you use any other type like a jubilee?
cv boot clip
11-11-2014, 02:22 PM
Got a jubilee on mine and it seems to work alright
Why can't you get the clip on?
11-11-2014, 02:29 PM
have used zip ties with much success in the past, but now have the crimper tool for doing the proper clips
the proper clips need a special tool for tightening, which to be honest is worth getting if you're going to do a few in your lifetime you'd have to be certain if using a jubilee clip that the head where the screw is doesn't foul on anything when the driveshaft rotates. zip tie is much easier tbh!
11-11-2014, 02:32 PM
jubilees are hateful on boots.
cable tie will suffice in most cases.
11-11-2014, 02:43 PM
As much as I didnt like the first time I used one as a temp fix...zip/cable ties have always done the trick for me.
Jubilee is likely to cut the rubber Wishes for more power...
11-11-2014, 02:44 PM
Never had a problem using the proper clips to be honest. Just use a pair of side cutters to add the tension.
But yea cable tie ftw if it has to be done!!
11-11-2014, 03:08 PM
would a zip tie be a mot failure?
11-11-2014, 03:17 PM
11-11-2014, 04:36 PM
(11-11-2014, 03:08 PM)jayspug86 Wrote: would a zip tie be a mot failure? no, why would it be? many cheap boot kits come with cable ties!
| retaining clip on rear carriers come off! | W1ll | 6 | 3,180 |
24-08-2013, 07:35 PM Last Post: Bender |
