Breaking: BREAKING Black ph2 GTi6 - Somerset
I’m breaking a 1998 ph2 GTi6 in black. Dials are showing 130k miles. Bottom end was changed approx 15k ago and the head was rebuilt (Invoices included).
[attachment=19994]
[attachment=19995]
Delivery on most items is no problem at competitive prices. All parts are available so just ask. A basic list below.
Engine/Suspension:
Engine minus the crank pulley and flywheel £275
Gearbox. Clutch is knackered so unable to give it a good test to ensure box is good, so selling cheap at £20
Nissens aluminium radiator £40
Solid rear lower engine mount £25
Adjustable gear rods £25 set
Rear beam complete minus calipers. £100
Fuel pump £15
Master cylinder £15
PAS high pressure pipe £20
Battery top clamp £5
Hubs (16mm) complete with ABS sensors £35 pair
Crank sensor £10
GTi6 front brake calipers with sliders and pads if required £45
Standard shocks and lowering springs £20
Fuel inertia switch £5
Fuel pump relay £15
Heater matrix hoses £5
OE wishbones ideal donors for fitting rollerbearings £15 pair
OE wishbones with powerflex bushes £25 pair
Master cylinder £15
Fans and cowling (complete with relays) £25
Steering rack with ram £20
Driveshafts £30 pair
Subframe £15
Panels/exterior:
Crystal headlights £30 pair
Front bumper £40
Rear bumper £20
Wings £10 each
Sideskirts £25 pair
Doors £20 each
Ph3 bonnet £30
Tailgate with wiper motor. Small rust spot £20
Ph3 spoiler (faded) £20
Ph2 spoiler (faded) £10
Grill £10
Hockey sticks £5 pair
Rear lights £10 pair
Front wiper motor £10
Interior:
GTi half leather/alcantara interior SOLD
Ph3 door cards £20 pair
Indicator twin optic light/fog stalk £10
Wiper stalk £5
Ph3 stealth parcel shelf with speakers £20
Heater motor £10
Silver centre console and vents £15
Clocks with 130,000 miles £10
Handbrake centre console and cubby box and ashtray £5
Steering column cowling £5
Radio control stalk £5
Interior mirror covers £5 pair
Visors £5 pair
Auto windscreen sensor £5
Clock/temp display £5
Heated rear screen/hazard switch £5 pair
Set of seatbelts, complete £5
Door shut looms £10 each
All prices are plus postage. I won't ship panels or larger items. I will have the shell for a few weeks so for any obscure requests, by all means PM me.
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
price on the boot trim and carpet if its any good?
Will i go any cheaper on rear Solís engine mount
Adjustable gear linkages please
Boot trim is quite scuffed from memory. Leave it with me, I'll have a good look in the light when I get a sec.
(09-11-2014, 06:08 PM)wibbz Wrote: Will i go any cheaper on rear Solís engine mount
I thought that was quite reasonable for a decent one already pressed into the mount. It's supposed to be a BBM one. It's not off at the moment so I haven't checked the markings to ensure it is BBM.
I can do you a powerflex poly one on it's own cheap if you like.
(09-11-2014, 06:10 PM)Paul_13 Wrote: Adjustable gear linkages please
No problem Paul. They are allegedly PugRacing according to the previous owner. I had a nosey and spotted the clips. They will be off in the next few days hopefully so I'll be in touch.
Bianca Rallye
BMW Z4 3.0
Interested in the rack. How much for postage?
Also, does this come with the earlier alarm system? I'm after the earlier ultrasonic sensors and a good length of the wiring.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
(09-11-2014, 06:49 PM)Alan_M Wrote: Interested in the rack. How much for postage?
Postage depends on weight, wouldn't be able to tell you without weighing it when it's off. Are you in a position to fit new track rods? If so I can just cut the rods off and make it easier to send.
No idea on the specifics of the alarm type. Are there any paricular identifiers that I can check for you?
Bianca Rallye
BMW Z4 3.0
Dibs on radiator!
Will PM you
Tom
Black 306 Rallye
Topaz Blue E39 530i Sport
Nordic Green 406 1.9TD
The mc a 2 port one?
Current cars
Subaru Impreza 2.0d - Daily
(10-11-2014, 04:18 PM)td_dan Wrote: The mc a 2 port one?
It is yes.
Bianca Rallye
BMW Z4 3.0
Is that 15 posted then Smile
Current cars
All prices are plus postage. Thanks
Bianca Rallye
BMW Z4 3.0
I'll also have the oe wishbones that need bushes mate.
Thanks
Send me a price then pal
Current cars
(10-11-2014, 07:12 PM)Paul_13 Wrote: I'll also have the oe wishbones that need bushes mate.
Thanks
Ok mate Smile
(10-11-2014, 07:21 PM)td_dan Wrote: Send me a price then pal
PM'd
Bianca Rallye
BMW Z4 3.0
Do you have front wiper motor and a relay also price (rough) for postage please.
(11-11-2014, 04:30 PM)Adam-m-h Wrote: Do you have front wiper motor and a relay also price (rough) for postage please.
Hi Adam
I believe you've been sorted by a local member. If not, I've a couple of motors here and postage is around a fiver.
Bianca Rallye
BMW Z4 3.0
Sorry dan was ment to message back, let me know when mc is off ill take it
Current cars
Hi Adam
Sorry I should of said
Mattcheese31 sorted it thanks
As long as it's a phase 2, it should have the ultrasonics I need.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
OK Alan. I've taken a day off tomorrow to start attacking it properly.
The sensors have plugs at the bottom of the A pillars. Do you want an extra foot or so past those plugs?
Bianca Rallye
BMW Z4 3.0
Made a good start on this, so I'll be working my way through requests and getting in touch with people.
Bianca Rallye
BMW Z4 3.0
I'll send through payment shortly
Sold parts:
Power flex wishbones
Standard wishbones
Pugracing gear rods
Fuel pump relay
Seats
Master cylinder
Crystal headlights
Clock
Steering wheel squib
Battery box.
Other requests, I am currently dealing with.
Bianca Rallye
BMW Z4 3.0
PM me for wishbones + poly bushes please Smile
(20-11-2014, 05:46 PM)ginge191 Wrote: PM me for wishbones + poly bushes please Smile
Sold as mentioned in the post above Wink
Bianca Rallye
BMW Z4 3.0
ah i read as far as someone wanting the norm wishbones, my bad! Big Grin
Rack and subframe sold.
Bianca Rallye
BMW Z4 3.0
Bump Smile
Bianca Rallye
BMW Z4 3.0
Front calipers, condition report? Smile
  Breaking - Black 98 GTi-6 Ben_w 40 23,009 26-09-2017, 07:27 AM
Last Post: Ben_w
  BREAKING - Diablo GTi6 93,000 miles Dangti6 15 11,270 25-07-2017, 12:51 PM
Last Post: Dangti6
  Breaking Black 3dr HDI Dturbo rocker8742 76 57,450 10-02-2017, 08:55 PM
Last Post: rocker8742
