307 brake vibration
My 307 has had a vibration on the brakes for a while now, it only happens when the brakes are pushed a medium force(the pressure used 99% of the time), light and heavy braking is fine, its the same vibration/wobble i used to get with a worn P bush, goes along the steering rack into the steering wheel, the pedal is fine
Iv replaced
Disks and pads
Inner and outer track rods
top mount bearing's
Steering rack
one wheel bearing
wheels and tyres, twice
Wishbone bushes, twice
Balljoint's
Im thinking its the wishbone bushes but they have been replaced this time with "firstline" bushes less that 500 miles ago and made no diffrence
Calipers might need servicing?
I cleaned and greased the sliders when i did the pads, pistons are fine
Well you didn't say that. Tongue
Does look like changed nearly everything though! Are you sure it's the fronts btw?
Dident say as it something that should alwase be done when the pads are out
it is the front, more front left too. Rear disks pads and bearing have been done, bearings are disks are one unit on this car, cost 180 for them alone
Passed the mot a few weeks ago with no advisories
  Nasty vibration coming from the rear brakes johnny625 9 8,736 12-04-2020, 10:26 AM
Last Post: johnny625
  Strange vibration. decjhawes 12 7,811 21-04-2017, 05:22 AM
  VIBRATION- balancing and tracking done thealphanoob 0 2,113 22-04-2015, 10:13 AM
Last Post: thealphanoob
