bolts on spacers
bolts on spacers
I've bought hubcentric spacers and Tapered bolts but the bolts don't seem long enough with flat seat washers, without the washers I get only 10mm of bite in the hub is that right?
I'm confused as they said they would be fine
10mm is plenty
(16-10-2014, 07:32 PM)kentiiboii Wrote: 10mm is plenty
That's using tapered bolts in challenger wheels with no flat seat washer in situ, is that dangerous?
Iirc all that washer is there for is to protect your wheel sort of thing?
I don't want to be driving down the road and lose a wheel or 4 ha ha
DO NOT run them without the washer in, it'll f*ck the wheels and they'll come loose. Sounds like they've sent the wrong bolts, you want to get a standard bolt and drop it through a wheel and measure the protrusion. If there's less than that with the spacer on and the extended bolts in, don't run them.
really f*cking stupid tbh, as they use flat seat bolts.
Cheers ha ha worth a try best get onto the e of bay and get some longer bolts, it has just been bought to my attention im actually going to be running the ATLANTIS wheels not the challengers so my wheels are 7j instead of 6.5j now I need very long bolts
I'm really confused, what bolts are we talking about? Picture of them?
Getting pictures now apologies for being such a dumb ass
OK here we are
20mm spacers washer and bolt
[Image: 20141016_215202_zpszgskagdx.jpg]
45mm thread length
[Image: 20141016_215231_zpshew21oxn.jpg]
Bolt through wheel with no washer and 10mm of bite
[Image: 20141016_215419_zpsxwwdyjvr.jpg]
bolt through wheel with washer and no bite
[Image: 20141016_215454_zpszp4kizcx.jpg]
wheels in question ATLANTIS 7j
[Image: 20141016_215302_zpsx5xu0rik.jpg]
yeh you need to get longer bolts buddy. Itll be easier to get longer tapered bolts and then use the flat seat washers.
OK, I've got 15mm for the fronts do you reckon I will get away with using the bolts supplied with the 20mm kit for the 15mm hubcentric's? ?
The wheel in the last picture is a Challenger, not an Atlantis. Atlantis doesnt have a cap in the middle, Challengers have. Look inside the wheel and check what it says, should say 17x6.5j
(16-10-2014, 11:51 PM)osm2121 Wrote: The wheel in the last picture is a Challenger, not an Atlantis. Atlantis doesnt have a cap in the middle, Challengers have. Look inside the wheel and check what it says, should say 17x6.5j
It says ATLANTIS 7J
there's 3 different types I own all 3
307 hdi with pop out cap
206 with recessed centre
206 with smooth centre
Atlantis with cap in the middle? Original? Never seen that, never heard of that neither, and doesnt exist in servicebox. Maybe its replica or they just made the hole in the middle? Easier to balance. That i've seen, even Cyclones with the hole made and center cap.
(17-10-2014, 08:42 AM)osm2121 Wrote: Atlantis with cap in the middle? Original? Never seen that, never heard of that neither, and doesnt exist in servicebox. Maybe its replica or they just made the hole in the middle? Easier to balance. That i've seen, even Cyclones with the hole made and center cap.
There's no cap it's a solid centre just has a recess for the wheel centre cap/badge genuine peugeot wheels not replicas, when im home I'll get a photo of all 3 wheels together so we can clear this up ha ha
Im just asking cause I never saw that wheels with the recess, im not questioning Wink
Neither had I mate until I bought a set ha ha 1st set are 180 wheels for sure then got offered another set of 5 wheels 4 being the recess and 1 a pop out centre
  Which wheel bolts? / WANTED - oe +20mm bolts laurence_13 5 5,134 15-02-2014, 10:59 AM
Last Post: Mattcheese31
  Alloy wheels, spacers, sprigot rings and bolts mspdan 2 2,156 06-01-2014, 01:56 PM
Last Post: mspdan
