Making brake lines
Will be changing my rear beam soon but need to make new brake lines. What's required all I could think of is: brake pipe (getting 25m), brake unions, pipe bender and flailing tool.
Is there anything else that's needed to make brake lines for the rear?
Something to cut the pipe cleanly and some fine ish sand paper/ file to debur.
Got a pipe cutter
Yeah getting a pipe cutter as well, so is that pretty much it?
Indeed Smile
Good to get some waxoil or similar to give it all a coat when done Smile
You want a flaring tool, not a flailing tool Tongue
Don't buy a cheap flaring tool like the common ones you see on ebay, in my experience they don't flare nicely. I have a sealey flared which is the same a the snap on/blue point. http://www.ebay.co.uk/itm/Sealey-PFT08-O...35dda066fd
(12-10-2014, 09:08 AM)Jonny81191 Wrote: You want a flaring tool, not a flailing tool Tongue
Spell check likes to put in words lol
(12-10-2014, 10:41 AM)Stef205 Wrote: Don't buy a cheap flaring tool like the common ones you see on ebay, in my experience they don't flare nicely. I have a sealey flared which is the same a the snap on/blue point. http://www.ebay.co.uk/itm/Sealey-PFT08-O...35dda066fd
f*ck that's a lot lol anyone got one I can borrow?
I used the cheap ones without a problem, was under £20 from Halfords iirc...
Can't find it on Halfords site, but it's this one - https://www.machinemart.co.uk/shop/produ...ake%20pipe
Have to agree those cheap hand held flare tools are ok for a temporary repIr but I would t make permant pipes with them in the Landy when we go off roading
The one I use is a sealey item and cost me £120 about ten years ago!
Don't forget you will need a good bleeding system aswell
(12-10-2014, 11:10 AM)Toms306 Wrote: I used the cheap ones without a problem, was under £20 from Halfords iirc...
Probably go for that one, it's just to get some rear pipes made up for my new beam
The one have cost about £30 and makes cracking good flares
(12-10-2014, 01:42 PM)Piggy Wrote: The one have cost about £30 and makes cracking good flares
What one do you have mate Smile
Signet one i got YEARS ago
I have this flairing tool and it's excellent, never failed to make a good flair, although it is a bit more money.
http://www.amazon.co.uk/Draper-SAE-Hand-...B008YFX2LM
What pipe bender are you getting? I have a cheaper version the type below and only really use it at the brake unions to keep things tidy, the rest is mostly done by hand.
http://www.frost.co.uk/brake-pipe-and-tube-bender.html
Yeah I would think buying a pipe bender is a bit over the top...esp when its so easy by hand and often the pipe needs odd bends and twists here and there that a pipe bender wont do
The bias valves use 2 different size unions also i found while part way tho so worth checking first
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  Braided Brake Lines TommiePuglet 0 2,469 21-09-2017, 02:10 PM
Last Post: TommiePuglet
  Disconnecting rear brake lines at the front Iaitoo 21 10,860 04-06-2016, 08:22 AM
Last Post: pug306driver
  Rallye Rear Brake Lines Eeyore 20 10,337 30-12-2015, 09:33 AM
Last Post: RetroPug
