Recommend Adjustable Drop Links
Hi Guys,
Ill be getting some baker BM solid top mounts for my avo gtz coilovers. Another thing I have been recommended to get is some adjustable drop links.
Can someone please explain why I should get these. What are the advantages and disadvantages?
Can someone recommend where to get some and how much they should cost.
As far as im aware when you lower a car the ARB gets pulled up which means it doesnt work as well? So in order to make it work properly again you have to have adjustable droplinks to return the ARB to the horizontal? Forgive me if im wrong...
Cheers
Sam
i made some using parts from mcgill motorsport on ebay, if i can remember it all cost me around £60 i used m10 rosejoints left hand and right hand thread for easy adjustment. A turnbuckle which i just measured a stock droplink then its just the missalignment spacers and bolts etc.
The 205 droplinks are slightly different due to the arb shape, but heres how mine turned out i would high recommend some rubber boots for the joints.
[Image: 903A3C4B-83A7-4B5D-9E10-3B331C105DE7_zpsltfvmk80.jpg]
You don't necessarily need adjustable, I've just fitted Ford Puma ones on the BMW, as they are 40mm shorter than OEM ones & my ARB sits too low if not.
(07-10-2014, 01:07 PM)JJ0063 Wrote: You don't necessarily need adjustable, I've just fitted Ford Puma ones on the BMW, as they are 40mm shorter than OEM ones & my ARB sits too low if not.
still shorter than standard though.
Yes, that's what I just said? Huh
So lay a standard strut side by side with your coilover, if there is a difference in where the droplink mounting tab is positioned, take that length off of the OEM droplink & find some droplinks that length, if the mounting tab is in the same place on the OEM strut and the coilover, you don't need shorter droplinks..
As you have said Sam, the idea is the ARB should be horizontal on level ground. Considering you use coil overs and have the ability to change your ride height, i would get adjustable rather than just a set shorter one.
Chances are you will have to make some up your self as i don't think any of the normal people make them any more. I know mine are Ripp ones and very good quality. I paid £60 for them second hand
I have some pro sport adj links if your interested.
Got any pictures? How much are you looking for them?
Pm'd.
I found you these on eBay:
http://pages.ebay.com/link/?nav=item.vie...1591195213
Bye Bye D-Turbo
Cheers. Those are what I saw on ebay too. Look very beefy! I had a look under the car yesterday and the ARB was too low. It was sitting below the wishbones by a good few mm.
(07-10-2014, 04:06 PM)Niall Wrote: Chances are you will have to make some up your self as i don't think any of the normal people make them any more. I know mine are Ripp ones and very good quality. I paid £60 for them second hand
I haven't done any for a while, but I do have enough to make a few sets up. I stopped doing them really after having at least 3 people order a set, getting materials, then having them argue over the price afterwards because some bloke on ebay is doing them for 80 quid, even though they're not the same spec.. Dodgy
So these days I'm not making any unless I've got a batch to do and deposits taken.
(10-10-2014, 09:08 AM)Jtrigga Wrote: I found you these on eBay:
ordered these just now Big Grin
Glad to know I've helped Smile
Bye Bye D-Turbo
You nutter Sam, I made my adjustable drop links, as Stef did, for less than £40.
  Damn spinning drop links Iaitoo 24 15,977 02-02-2016, 05:51 PM
Last Post: Iaitoo
  Drop links - and now tie rods :) Iaitoo 11 6,170 16-12-2015, 06:36 PM
Last Post: Frosty
  Drop links spec mattbarker32 27 13,445 06-08-2015, 04:05 AM
Last Post: maxzy
