Threads: 72
0
Car Model/Spec: 205 1.9 D Turbo (Full Gti Rep)
Given 1 thank(s) in 1 post(s)
I am about to freshin up my xud engine
New Parts:
Top end gasket kit/including steel h/g
Stretch Bolts
Crank seals
Valeo Clutch
Timing belt
Rec. Injectors
I have came across an dw block for free, is it worth fitting hdi rods?
I don't think I will strap a big blower onto this xud,
I will be staying on the t2 with gov mod,lda pin mod, around 25psi
Its going into my 205, so its a light shell
Threads: 371
29
Car Model/Spec: ford fiesta
Given 82 thank(s) in 82 post(s)
If you have the block stick them in. Hdi rods are better. I think they have a beefier top half. But not fail safe. Id put them in though. Will do on mine at some point.
Threads: 226
24
Car Model/Spec: A3 TDi
Given 0 thank(s) in 0 post(s)
For free? Definately. They are bigger around the wrist. You could also balance them whilst changing them over.
Threads: 72
0
well I have a full dw10 engine for free...
but I don't fancy changing rods for something that "might be" safer
Threads: 591
54
They will be safer.
Everything has a limit though.
Nothing is 100% safe
