Car Model/Spec: 306 D Turbo
30-09-2014, 05:58 PM
(This post was last modified: 25-10-2014, 03:02 PM by londondan86.)
Evening chaps
A friend of mine has a p3 hdi and the wipers have started acting up.
The intermittent doesn't work at all. The single swipe doesn't complete it's cycle (stops in the middle of the screen). Wipers do not work with the washers. Normal setting and fast setting works perfectly?
So far I have checked the 2 purple relays which are both good and changed the stalk for a known good one.
The next I suppose is the motor but first wanted to point out that the screen was changed for one that doesn't have the rain sensor, not sure if this is relevant.
If sensor isnt plugged in, it just reverts to intermittent.
But the fault sounds like a internal motor fault. The tracks and contacts get worn out.
You can replace or rebuild and regrease it
81
check the earth on the drivers side near the washer fluid filler. My headlights were dimming and the wipers were getting stuck halfway through their sweep.
Threads: 87
48
Hopefully it'll be the wiper motor, not bad to change, but one of my old DTs I changed the, relays, the stalk and the motor and it did sweet fa... Thankfully that car snapped its camshaft so I don't have to worry about the wiper probkem anymore
Thanks gents. Motor was my next port of call. Just wanted to make sure that it wasn't the rain sensor causing odd issues.
I'll check the motor out and try to clean the contacts before replacing it. Any guides on this or is it pretty self explanatory?
Pretty simple
Strip it off to just the motor. The backing plate has 5/6 screws, remove carefully. You will likely find worn tracks and contacts and a lot of old solid grease.
Remove said old grease. Clean the tracks up with a bit of wet n dry. Bend the contacts SLIGHTLY to add with contact pressure and regrease nicely.
refit it all back in!
Legend piggy. Cheers pal, I'll have a go after work tomorrow and update.
Or you open it up and find its full of water with what looks like cheese but is presumably wet grease and wish you'd just swapped it for another.
Don't understand why you'd fit a non auto screen to it though?
Threads: 136
11
Mines doing the same but it works with the washers
01-10-2014, 02:06 PM
(This post was last modified: 01-10-2014, 02:07 PM by londondan86.)
(01-10-2014, 09:52 AM)Toms306 Wrote: Or you open it up and find its full of water with what looks like cheese but is presumably wet grease and wish you'd just swapped it for another. ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif)
It wasn't me that fitted it (or had it fitted). The owner didnt have windscreen cover so a standard screen was £140 and the auto screen was £225!!!
(01-10-2014, 01:10 PM)Paul_13 Wrote: Mines doing the same but it works with the washers
Could be related? I'll update later once I've had a go at cleaning it out.
Threads: 41
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
Recently opened up and cleaned mine as the wipers needed assistance to get going.
Now it works perfectly.
15 min job really.
(01-10-2014, 02:06 PM)londondan86 Wrote: (01-10-2014, 09:52 AM)Toms306 Wrote: Or you open it up and find its full of water with what looks like cheese but is presumably wet grease and wish you'd just swapped it for another. ![lol lol](https://www.306oc.co.uk/forum/images/smilies/legacy/lol.gif)
Sorry, I meant 'why anyone would fit one' not specifically you lol.
That's a pretty significant price difference though! I take it that's not solar reflect tinted either.
Threads: 136
11
I've just received my replacement wiper motor. I'll see if it cures it
Well went all out and stripped it down and rebuilt it and still exactly the same. Replacement motor needed by the looks
(02-10-2014, 09:09 AM)Paul_13 Wrote: I've just received my replacement wiper motor. I'll see if it cures it
Please do mate
Threads: 136
11
I'll be looking at this later. Got a replacement motor and stalk.
I'll keep you posted
Threads: 136
11
Replacement wiper motor solved my issue. Works fine now
Just to update this. Piggy you are wrong!!
After 2 motors, a stalk and 2 relays the problem was that the rain sensor was missing. Got one from the scrappy and plugged it in. Now all wiper functions work.
Threads: 87
48
(25-10-2014, 03:01 PM)londondan86 Wrote: Just to update this. Piggy you are wrong!!
I fcuking knew it!!! That's what I'd narrowed it down to on the missus's old car too, didn't get round to it before it died though, good to hear though, I'd changed everything else
Chalked up to experience I suppose. Oh well
All functions work? Presumably except intermittent if you now just have the sensor hanging there lol?
I have had mine unplugged before for weeks with no issues whatsoever.
I know others have too!?!
At least its fixed
(25-10-2014, 07:29 PM)Toms306 Wrote: All functions work? Presumably except intermittent if you now just have the sensor hanging there lol?
It's stuck with double sided tape to the windscreen so all working 100% Not been out in it in the rain yet though!
(25-10-2014, 07:53 PM)Piggy Wrote: I have had mine unplugged before for weeks with no issues whatsoever.
At least its fixed ![ThumbsUp ThumbsUp](https://www.306oc.co.uk/forum/images/smilies/legacy/Skype/yes.gif)
Yea yea!!! ![Tongue Tongue](https://www.306oc.co.uk/forum/images/smilies/tongue.png) lol
Either way it works so thanks to yours and everyone's help
Threads: 0
Car Model/Spec: 306 Lx D
Country:
