95 DT with immobiliser bypass
Turns out my 95 plate DT has an immobiliser system of some sorts.
Who knew.Huh
Imagine my surprise when I removed the battery and discovered the headlights started flashing when it was reconnected and I couldn't start it.
Since the buttons are screwed for the IR and I had no batteries, what to do.
Turns out if you turn ign to pos2, disconnect and reconnect battery, it becomes disabled again.
Genius.Itwasntme
Nice tip. My 406 had a stupid keypad immobiliser. To remove it you just enter the code and start the car. While it is running, unplug the keypad and voila no more having to type in codes anymore.
That's the alarm, you have keypad as well yeah?
No keypad. Just an IR receiver and some old skool style ultrasonic sensors in teh A pillars.
  central locking bypass auto unlocking andyw 1 3,431 04-07-2021, 03:58 PM
Last Post: Mighty306
  Changing ECU to bypass immobiliser? TurboJeppe 1 2,643 08-05-2017, 06:54 PM
Last Post: TurboJeppe
Thumbs Down Immobiliser thebluepearl 11 5,444 20-05-2016, 12:05 PM
Last Post: insomaniac45
