Xsara VTS Steering Rack on HDI
Anyone done this? Worth doing?
Suppose to be a quick rack, worse than the gti6. But can be done.
Well worth it but make sure you get a rack from a PH1 VTS. The PH2 is .2 of a turn more...doesnt sound a lot but does make a difference!
So i tell the missus anyway Wink
ment to essentially be a quick rack no? depending how many less turns to turns it is id say it deffo worth it
Thanks lads, would it make the steering heavier and put more strain on the components and tyres due to the VTS having higher gearing and a different turn to turn?
Phase 1 VTS rack will go straight on. To fit a Phase 2 VTS, you'll need the PAS pipes too as they're unique to the rack.
I have one of each in my garage, plus the 2.4 manual rack on the 205. I would've fitted the Ph2 rack to my 306 during the overhaul but I lent the pipes to Paul_13 for his 205 and I'm not sure I can be arsed to fit it now.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
(25-09-2014, 10:24 PM)MY95 Wrote: Thanks lads, would it make the steering heavier and put more strain on the components and tyres due to the VTS having higher gearing and a different turn to turn?
shouldnt imagine it would change the heaviness of the steering atall just quicker steering Smile its a mod im planning on doing
If you're fitting them on a hdi you'll be able to get the pipes off a late xsara hdi, same fitment apparently.
What I'm planning on doing with a ph2 Vts rack on the hdi.
Do you want me to get you a set of those pipes Alan?
(26-09-2014, 06:02 AM)Paul_13 Wrote: If you're fitting them on a hdi you'll be able to get the pipes off a late xsara hdi, same fitment apparently.
If you can (and if they are the same), but there's absolutely no rush. As I said, I can't be arsed to fanny about with the HDi now, the 205 is begging to be worked on (that's getting the Ph1 VTS rack and electric pump setup).
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
(26-09-2014, 08:38 AM)Alan_M Wrote: ...the 205 is begging to be worked on
Christ alive, I never thought that I'd see the day!
Shut it, beatnik Smile
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Quick rack ftw
306 Rallye giving people a surprise because they think shes a 1.6 ;-) Silly people
  Power steering rack.....replacement options Jellomanpie 9 9,459 30-04-2020, 05:54 PM
Last Post: Mighty306
  306 PAS steering rack ratios mattsrallye 14 8,926 23-02-2017, 06:11 PM
  Steering rack piston cover doogle-d turbo 2 2,921 10-07-2016, 04:19 PM
Last Post: doogle-d turbo
