23-09-2014, 07:52 PM
cant get my fog lights off can someone help, cant figure out how to get them out
help please
23-09-2014, 08:16 PM
What phase? And what have you tried already? You usually take the connector off and take the screws out
Team disASTOR? ![]()
23-09-2014, 08:31 PM
phase 1 and der is only 1 bolt holdin them on (or so i can see) even wit the bolt off the fog lamp wont come away from the bumper its really puzzling me!?
23-09-2014, 08:34 PM
probably be faster to take the bumper off then you can see all the bolts
23-09-2014, 08:50 PM
how would i go about doing so?
23-09-2014, 09:53 PM
3x13mm nuts either side on the lower slam panel, you need to go from the inner archs n/s is quite easy to access o/s a wee trickier unless you remove the washer bottle or your used to not being able to see
23-09-2014, 10:53 PM
Take the nut off the bottom, disconnect the wiring and wiggle them out..
26-09-2014, 12:26 PM
3x13mm? Is it different on the ph1s? Every 306 i've worked on it's 2x10mm each side.
