phase 1 radiator system disaster
Was just driving home from the hospital and my radiator split pretty bad just wanted to no if a phase 2 radiator is the same as a phase 1 and if there a straight swap or no as i have a spare one if also what antifreeze is the best to use
Thanks Rhys
They are different, ph1 have the header tank on side and ph2/3 have them seperate, and the bottom pipe is different I think
So there is no way of swapping the header tanks over
Its the bottom pipe that is the main problem tbh.
But no you couldn't swap the headers, it's integral on the side of the rad.
Damm so I'm just going to have to buy one then any for sale in Cornwalgl Smile
Yes you can use the p2 but you will need the rad, hoses and expansion tank as a complete swap
HDi Cabby Project Click
  Changing phase 2 radiator to phase 1 Ben 10 6,240 21-03-2013, 08:22 PM
Last Post: Daniel306
