Suspension Problem
I have a knocking noise coming from the front passenger side of the car.
I can twist the turny bit in the photo on this side but not the other.
There sounds like theres a releasing of air when this problematic side is pushed down on.
New spring and shock absorber fitted only a few thousand miles ago.
Any ideas?
Photo of the bit I can twist:
[attachment=18472]
The top nut is probably a bit loose if you can twist the metal spacer thing, that'll cause a knock over bumps.
A quick 'gushing' sound is normal as the oil/gas moves in the shock.
  Front suspension problem Welshy_Pete 14 7,428 10-02-2015, 11:14 AM
Last Post: Welshy_Pete
  206 suspension users? Rock hard suspension HDIkyle 10 8,166 10-05-2013, 05:29 PM
Last Post: puglove
