206 suspension users? Rock hard suspension
Got a set of brand new TA coilovers with rear shocks from a 206. Fit on perfectly fine with new top mounts ofcourse however. Its rock hard there is no travel at all. They compress fine by hand off the car when fitting ect but while driving there is no travel from them. If yo hit a bump the whole back end just bounces up even full body weight jumping in the boot it only seems to be tyre flex?
I was told 206 suspension was abit too soft for a 306!
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
It's probably on the bumpstops...
^^ this...
Miles away from the bumpstops
its an standard height axle also
Blaze 1.6 Dead
Are you meaning it's ONLY the back end being uber bouncy?
Well its all around is hard but the back end in particular Ye Its solid. Fronts not low still got both springs in
Blaze 1.6 Dead
That's weird.. if anything you'd expect it to be super soft...
Cant see any reason for this other than the 206 beam is so different that the rear shocks are on full compression at standard height on a 306.
What is the overall condition of the beam?
The 306 is much heavier than a 206, springs/shocks are probably more compressed under the extra weight so they've lost the 'bounce' travel.
Just my opinion any way.
Hmm it don't look compressed it don't drop when jacked up anyway have a look on my project thread
Blaze 1.6 Dead
Looks higher now IMO
  Front top spring suspension Welshy_Pete 4 3,862 21-04-2018, 09:52 PM
Last Post: Mighty306
  P Bushes Suspension Welshy_Pete 13 7,906 09-12-2017, 01:24 PM
Last Post: welshpug
  Suspension Spring Top Cups Eeyore 19 10,871 03-01-2017, 08:17 PM
