Is there a snapring removal tool ?
What is the best way to get these snaprings out as they have no lugs so normal circlip pliers are no use. I have in the past cut them with a dremel and using a screwdriver to prise out but its easy to leave scores on the drum[Image: gazy9eme.jpg]
Big socket from other side and tap it out
Team Doesn't own a 306
Im talking about the snapring not the bearing mate
Sharp punch and hammer. One or two good hits will split it. Then re-new
Cheers I eventually got it out with sharp chisel, damaged part of the drum where the snapring sits but feck it. Cheers
Doesnt matter if its a little damaged. Smile
  What Tool Did You Use? Crankshaft Pulley Bolt Removal td163 31 22,473 02-04-2015, 02:52 PM
Last Post: td163
  remap tool tysonbully2k12 3 3,691 28-09-2014, 02:05 AM
Last Post: pro_steve
