Bosch Injector Question
Are the injectors the same on a car with a mechanical bosch pump as on a car with a semi ecu controlled pump?
I have just bought a bosch pump and I have a Citroen synergie which i was going to use the lines and injectors from but it has the ecu pump like the 406 one.
1 of the injectors will be taller and have a wire running off it but im pretty sure you can just snip the wire off and it will be fine to use
Yeah i noticed the wire which prompted me to ask the question.
  Bosch Pump Question Stuart C 10 7,605 04-10-2016, 06:37 AM
Last Post: Matt-Rallye
  Bosch pump plumbing question 089 4 4,190 11-04-2016, 02:55 PM
Last Post: zx_volcane
  ANOTHER Bosch pump question. 205dtub 7 5,322 02-12-2015, 06:19 PM
Last Post: 205dtub
