V6 COMPLETE CONVERSION
Up for sale is a complete conversion for a 3.0 V6 conversion, i will include the subframe / engine / gearbox / wiring loom with unlocked ecu modified clutch setup, will be removed complete so readt to drop straight in. £650 plus postage, Most of UK mainland is £50 Del
£650 seems a bit steep to me. But I'm not 100% clued up whey those parts are worth.
It's not considering how much you'd pay if you started the conversion from scratch.
62k Diablo Phase 1 Gti-6:
Project Thread
(03-08-2014, 09:43 AM)Ben Jay Wrote: £650 seems a bit steep to me. But I'm not 100% clued up whey those parts are worth.
Not when a standard engine with loom and gearbox sells for around £350, With this your getting all of that with unlocked ECU / Hydraulic clutch to cable conversion parts / modified subframe / radiator and piping and custom engine mounts, custom driveshafts etc
Regards
Would love to drop this lot in a ph1 roland garros cabby, but too many projects already!
(03-08-2014, 12:51 PM)RetroPug Wrote: It's not considering how much you'd pay if you started the conversion from scratch.
I had mine done by pug1off Jan last year and correct it was not cheap so £600+ is a good price as long as the engine is at the correct tilt and position.
Is the drivers side engine mount a bolt in or weld in one?
  Complete HDi to DT Clutch conversion Chris 3 2,355 25-02-2012, 04:12 PM
Last Post: Chris
