Arb bushes.
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
Arb bushes.
My arb bushes are f*cked, the arb is knocking its tits off now.
I was saving for some powerflex bushes but its doing my head in.
So just wondering if there's any cheaper upgrades out there.
Obviously I have a gti6 so it's thicker arb.
Thanks in advance.
Tried ringing peugeot and asking for a price on genuine ones?
62k Diablo Phase 1 Gti-6:
Project Thread
No I hadn't, will give them a call later on cheers.
No problem.
I don't think you'll notice much of a difference fitting 'uprated' ARB bushes, at least from what I recall reading on here or the gti6 forum.
Perhaps someone will correct me though. lmao
Project Thread
Slightly off topic but how easy is it to fit a gti6 ARB? would i need to drop the subframe. Would also be looking to get upgraded bushes.
subframe would need dropping, no I would not recommend fitting a bigger front arb, standard bushes are enough.
Stiffening the front ARB and not doing anything to the rear roll stiffness will likely increase understeer.
Project Thread
Standard pug bushes it is then cheers lads.
