Fault codes hdi
Got a couple of fault codes coming up on the scanner
Anyone any ideas
Intermittent faults
Additional heating circuit short circuit to positive
Flow sensor signal open circuit or short circuit to earth
Clutch switch signal consistency with vehicle speed
Cheers
The heating circuit is four glowplugs plugged into your coolant, helps warm the car up when you first start it of a day. Fractionally helps with economy and means you have warm air to clear the windscreen quickly, but really not needed. Leaving it as a fault shouldn't cause any problems for you.
The flow sensor signal fault is your maf, that'll need replacing.
The clutch switch one i'm not sure about and cba to google it myself right now.
Thanks mate
  Multiple HDI ECU error codes allye 16 8,770 29-06-2016, 04:01 AM
Last Post: Paul_13
  2001 Hdi estate Fault codes lordon301 8 5,725 02-02-2015, 07:46 AM
  Fault Codes P0221 & P1521 Alan_M 4 4,790 17-09-2014, 01:06 PM
Last Post: mr_fish
