28-06-2014, 10:09 PM
That is what I am interested in...anyone know how?
Though I am a fan of Darren j Lobb`s XUD handiwork!
xud9te super economy set up?
28-06-2014, 10:15 PM
1) Fit a bosch pump
2) do a mild stage1 tune 3) run on veg oil for 50-75% of the cost of diesel
28-06-2014, 10:25 PM
Is there a way without veg oil, just using pump diesel, I figure that the amazing increase in power by relatively small adjustments to fuelling boost etc to the XUD9TE would suggest that economy (though not a popular thread) could also be tweaked in some way, I am a full on newbie mind!
28-06-2014, 10:26 PM
Its known that a stg1 tune will improve economy.
You could reduce fueling a bit...but you may find the need to boost more to get going!! Wishes for more power...
28-06-2014, 11:05 PM
GT15 or newer if you can.
VE pump. Tweak Injection quantity a little for improved torque. Play with timing until best results are achieved. Went from the original T2/K14 and ~45mpg to a GT15 which gave low 50s to the GT20v and instantly was up to 58mpg on a run - amazing the efficiency gains from modern turbochargers.
29-06-2014, 05:40 AM
I'd be interested in an economy setup too doing 100+ miles a day to work and back.
Are the GT15/GT20v direct fits ?
30-06-2014, 09:31 AM
So what vehicle would I find the GT15 on ?
30-06-2014, 09:33 AM
Very late XUD9s - Generally on a T plate.
30-06-2014, 09:39 AM
What Ruan said, aside from making sure your running a bosch pump with good injectors / timing, the best thing that will effect your MPG is the turbo....
You wouldnt believe how far turbo technology has come fowards since the old T series....They can move air so efficiently now its unreal... | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
30-06-2014, 10:07 AM
My car is on a T plate, so does that mean I might have the GT15 already ?
Just need to sort out a Bosch pump setup now...
30-06-2014, 11:50 AM
Ive got a gt15 you can have. Ive recently blown it up though
30-06-2014, 04:13 PM
for infinite mpg, leave your car at home and walk or cycle
/Toseland
30-06-2014, 05:26 PM
30-06-2014, 06:48 PM
then bosch, stage1 and veg = the winning combo..
/Toseland |
| Tuning for economy | DavidA | 11 | 5,860 |
07-05-2014, 05:22 PM Last Post: Mattcheese31 |
| De-tuning a xud for economy? | Andy annear | 18 | 7,622 |
20-03-2014, 07:24 PM Last Post: Tom |
| Fuel economy tips | WiNgNuTz | 30 | 14,984 |
04-10-2013, 12:01 PM Last Post: silverzx |
