Rounded my waste gate lock nut
as title, on a t2 any suggestions on what i can do?
hammer and chizel it open, and replace??
small mole grips?
Pull the actuator off; 2 or 3 10mm nuts holding it to the compressor housing and the circlip at the wastegate end. Then replace it with another nut or another actuator. Should be able to pick up an actuator for cheaps off somebody whos blown a T2 up and still got it laying around Smile
If your trying to increase your boost just get an MBC, job done, if your trying to decrease then just reduce your fuel. Thats avoiding the problem, but meh
ginge191 Wrote:hammer and chizel it open, and replace??
small mole grips?
Tryed lol no good i cant get the nut or the end of the arm off they are dead tight
Then id suggest what dan said - remove the actuator arm...
  rounded off glow plug Chris_90 22 13,566 08-12-2014, 08:10 AM
Last Post: Chris_90
  Waste veg oil filtering Chris_90 17 12,352 16-03-2013, 09:48 AM
Last Post: Chris_90
