Boost gauge T-piece
Boost gauge T-piece
what size T-piece is needed to fit a boost gauge?
6mm maybe?
where to source one?
Yeah pretty sure its 6mm. Best to have a look on ebay
Halfrauds sell em. Or, IIRC, the T piece from washer jet pipes fits. Grab one next time you're in the scrappy, maybe worth a check?
ebay they're 99p...
8mm for 99p: http://www.ebay.co.uk/itm/Tpiece-straigh...2c5e6afc83
4mm for £1.27: http://www.ebay.co.uk/itm/4MM-T-PIECE-HO...53f47537f9
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
had this one in the end as i missed the other links *woopsy*
http://www.ebay.co.uk/itm/190885965346?_...EBIDX%3AIT
8mm--4mm--8mm
fitted a treat!
6-4-6 would be best, you should ideally be using 4mm id for the gauge hose anyhow
/Toseland
Is using a t piece the easiest way on an xud or is there somewhere to drill and tap?
T piece has to be the easiest way.
Takes 2 minutes to join t piece and run hose into car.
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
Where to t into on these, i know on the hdi t-ing is a pig, but going to help fit a boost gauge on one of these soon.
you ahve the intercooler, then the best way is to T into the line that runs from the intercooler to the boost compensator on the pump./
that is most common anyhow
/Toseland
Cheers guys. Should be able to figure it out.
It depends what size hose your gauge takes really.
the one which arrived for me.
[Image: IMG_20140620_191551_zpsgbnybicd.jpg]
Make sure you get a T-piece with anti-flutter in it. Nothing more annoying than a boost gauge that shakes more than harlem
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
  Boost Gauge Decisions CJRODELL 7 2,029 22-12-2014, 10:16 PM
Last Post: CJRODELL
  Boost gauge help? Ryan'dolan 2 1,072 20-09-2014, 08:40 AM
Last Post: Piggy
  Where to T-piece Nathan1305 9 2,324 15-08-2014, 12:52 PM
Last Post: Danny2009
